Screen Lock Widget help
BK2712
Visitor
How do i add lock screen widget on Xperia T? Am running Android 4.3 version 9.2.1.205. There is no option in Settings > Security to enable widgets.
- BK
6 REPLIES 6
faisal3dfx
Visitor
You can add a limited number of widgets to the lock screen.
Lock your screen then press power button once. Don't unlock your screen (your security must be on swipe mode). On the top where the clock is showing swipe to right and there you'll find a + button. Tap on it and you'll see a number of widgets to chose.
Thanks
profile.country.RO.title
_alexdon_
Do you have a PIN/password to unlock the device?
alexdon
BK2712
Visitor
Alexdon: Yes. Have enabled PIN to unlock the device.
BK2712
Visitor
It doesnt show + button :(.
_alexdon_
Remove the PIN,that way it should work.
alexdon
faisal3dfx
Visitor
I told you that your phone should be on swipe mode if you use pattern/pin/password to unlock your device then you cannot use lock screen widgets.
Remove your pin and then try.
