Hi All,
Can someone tell me why SE X10 mini battery performance so worse?
How come my bluetooth device although been paired but still can't send/receive any files?
Are X10 mini available for the file manager? it is quit inconvenient if without file manager.
What is the latest firmware version now other than version 1.6 for mini?
I am start disappointing with this phone, it is not very friendly usage to me.
Rgds,
Shakababe
you can download blue tooth application from below site.
www.medieval.it/content/view/61/85
Using this you send files and recieved from x10 mini. But I dont know how to allow other device to send receieve. FOr other questions i do want to know answer.
As I understand it, Android 1.6 does not readily support Bluetooth file transfer, so this affects X10 and X10 Mini alike. This should be supported when the X10 upgrade to Android 2.1 happens later this year.
As for battery usage, I had some issues with power as well. At first, the phone would need charging every day when I got home. But then, everyone I know who has an Android smartphone (and people I know with iphones) have the same issue - if you use automatic syncing of email/calendars, or regular WIFI or GPS or bluetooth you will probably need to charge the phone every night.If you use all of those constantly then you may only get 8-12 hours usage.
I get a couple of days out of my X10 Mini by using the Power Control widget to switch off Wifi, Bluetooth, GPS and background data/syncing. Also, the screen uses a lot of power so use the brightness control (also on the Power Control widget) to set the brightness to be no higher than you need it.
