proximity sensor issue
rahul39654
Visitor
Hi I've sony xperia tipo its having proximity sensor problem sometimes sensor shut off the screen while calling and doesn't shuts on the screen till th e call is not ended and sometimes it keep light up while on the call. And I have upadated to latest software but still not working and in system check its says "detected"..
4 REPLIES 4
profile.country.RO.title
_alexdon_
Do you have a screen protector or a flip case?
alexdon
rahul39654
Visitor
I have screen protector
_alexdon_
You should remove it and check again.
alexdon
Alexander1
Champion
If you experience the same behavior without a screen protector you can try to reinstall/repair the phone software using PC Companion:
http://www.sonymobile.com/update
In PC Companion, press start on Support Zone > Start on Update the phone/tablet software > Press the blue link that says "Repair phone/tablet".
Before repairing the software in your device you may want to backup your information first. Check out this topic for more information on how to:
http://talk.sonymobile.com/t5/FAQ/Backup-amp-Transfer/m-p/407253#U407253
If the issue persists, I suggest that you have your phone examined by a service center. Please contact your local Xperia support team for more information:
http://www.sonymobile.com/global-en/support/contact-us/
