Problem with Xperia Z1 Camera
Raz
whenever i am using my z1 to take images frequently after taking 3 to 4 photos camera got freezed. i had tried so many times same result found.please fix this bug.
it's iritating.
10 ANTWORTEN 10
Uliwooly
are you saving the pictures on the internal storage or SD card?
Uliwooly
Also try
settings > apps > all  > camera > clear data > restart your phone > check again
hamcastle
Having the same problem with my wifes Z1 compact, Have checked with some japanese websites and apparently alot of people over there are having the same problem. The issue reported in Japan seems to be that is you use your camera a lot the phone heats up and then the camera freezes - this fits exactly with our experience. Unfortunatly Sony Japan  are not recognizing this as an issue
Edguy555
Again removed to comment, but what is it! Problem is the same! I can prove it many times logs. I reproduce it easily, camera data is erased before the experience and reboot the phone.
VikeDid
Go to Safe mode. Then see if it helps. If it doesnot even after that, software problem. Get a repait using PC companion
Edguy555
Does not help, took a lot of time and PC Companion will not help (also tested many times)!
Raz
@uliwooly,iam using internal storage for camera storage.
Edguy555
It is very strange that Sony developers can not recognized this issue!
johnlegend
sony never solved the bad picture quality software since the xperia z released and now from 4.4 update this camera freeze and camera error for z1 z1c z ultra and z2
