Good morning
With latest FW .185, on 6.0 MM, I noticed something really bad during some calls
Calls switched immediately by 4G to GSM, without going firstly to 3G so I had to check more things and I went into
Settings - Other - Mobile Networks - Prefered network type and I had yet flagged 4G-3G-GSM AUTO !
But doing some other searches, I went into *#*#4636#*#* and I noticed that in Info Phone I had instead : "LTE/GSM auto and infact, calls under WIFI goes directly to GSM and I noticed so bad calls while before with .163 FW calls were better ....
However I've never had all these problems during some calls as with this phone under WIFI
Could u help me to understand ?
This is probably how your carrier/network handle calls and data, is your phone network branded?
Uli I can confirm u that situation has not improved !
Don't know more what to do
I just tried to attempt for a call, but while I was waiting that the called answered, I saw by SIM STATUS that phone went by 4G to 3G immediately and then after some seconds it went to 2G with a decadent call quality
All this happens under WIFI ! No mobile connection !
I'm thinking :
Pershaps is there something to reduce drain battery when we're doing a call, under WIFI, regarderless about strenght line power.
Mine goes back and forth between 4g and 3G during a call, but both signals are good and neither communication nor connection are affected.
I am running an unbranded Z5c under revolving Vodafone SIM card.
