Help With Xperia J
GalWain
Visitor
Help With Xperia J
i have sony xperia J and I update my phone to new version from into the phone.
The update is not completed and failed middle.
The update is not completed and failed in the middle, the phone turned off and turned on, appeared next image:
Android does not work and stuck in this situation
what can I do?
27 REPLIES 27
GalWain
Visitor
I dont understand.
How do I get the state list have the option XPERIA J?
profile.country.RO.title
_alexdon_
Right click on the executable,properties,compatibility tab,run in compatibility mode with windows 7.
alexdon
GalWain
Visitor
i succses to do this,
but the software writing to me 'no new software is available for your phone. your phone already has the latest available software installed'
and the situation not change.
Appears to me a sign of a download with a yellow exclamation mark as before
_alexdon_
You should be able to repair.Doesn't it prompt you?
alexdon
GalWain
Visitor
no, isnt important to me
how i do this?
_alexdon_
It should let you repair if you want.Try to repair with PC companion:
http://www.sonymobile.com/gb/tools/pc-companion/
alexdon
GalWain
Visitor
how i do this?
you have a guide to give me plz?
_alexdon_
You just need to connect the phone to your PC and it will check the firmware after which it will let you repair.
alexdon
GalWain
Visitor
i dont know how to do this
_alexdon_
What are you using?sony update service or pc companion? Just open the software,it will tell you when to connect the phone while it is turned off.
alexdon
