help!!!!!!!!!gmail and gtalk signout problem
Not applicable
hiee!!! i once logged in gmail with my 2nd gmail account and now i want to lagin my other account but its not working Crying_Face i signout 100 times and off the automatic sign in...but still struggling... plsss help !!!!!! thanks in advance
5 REPLIES 5
higwayman
Visitor
x10 right!
1) setting
2) application
3) manage applications
4) Google Apps, clear data/clear cache
5) access market again, it will prompt you to sign in google login again,
6) use your preferred login
Not applicable
Actually i did clear cache then i again click gmail its again show me logged in with dat same id Slightly_frowning_Face the way u said can solve my prob?? i cleared d cache for gmail and gtalk
higwayman
Visitor
uninstall gTalk
clear cache again and try again!
Seems you are using different google login and gTalk
Not applicable
i think there is no uninstall button for both of these as they are factory soft .... yaa i m using both i dnt use market...
higwayman
Visitor
you should check using  your computer and access the gmail account and see if they are ok.
next step on phone is probably a factory reset -  Setting/SD card & phone storage/factory data reset
backup all your stuff or reload later. careful and at your due deligence
