Here're the facts:
- yes, I have the Stamina-Modus on.
- all locating stuff is off
- only whatsApp active
sometimes, the battery lasts for 2 days and sometimes, like today it get's quiet hot and unloads within minutes (it was at 70% five minutes ago and is now empty)
What else can I do? I'm no technic crack....should I send it in for repair? Or does someone else had the same problem and knows a solution?
I love that phone and don't want to change....
Thanks for ideas!
Blauanina
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
That sounds strange. I suggest that you check the battery usage on your phone via Settings > Power Management > Battery usage. TThis list will show what have consumed battery since the last charge, so check the list when you have around 10% battery. You can also take a look at the following FAQ to see if you can find any tip:
http://talk.sonymobile.com/t5/FAQ/Battery-time-and-enhancement-features/m-p/347874
Thanks for the reply.
I tried most of it.
no live-backgrount, bluetooth off etc.
Only on is whatsapp and WiFi.
The battery usage says that google - stuff needs the most. But that I can't switch off as it is main functional stuff you can't change...
I've already disabled the location-function. That worked a while....but since a week it get's strange. Like today the battery unloads within minutes and gets hot.
I can't switch off all functions - if so, I should use a normal mobile and not a smartphone..... ;o)
Thanks for some more ideas/help !
If I can't get it solved, I think I send it to repair / new battery ? Buy another brand? Whatever the solution might be....:smileyexclaim:
take your sd card out and restart it, don't put the sd back because it might be broken
worth a try.
but first I need to safe the data of the sd-card.
I'll keep you updated if this is the solution !
THX for the ideas..
