What you described seems to be a hardware issue, contact your Local support to get your device inspected.
But you said:
@SajjanXperia wrote:
Hii all...
1). I have a little problem with headphone jack on my phone.
Whenever I'm listening to music, a little bump on the pin or if the pin(3.5mm jack) gets rotated.. The Walkman pauses playing... What to do.. Is there any problem with the headphone jack?.. I have also tried it with other headphones but still same problem...
That seems like a hardware issue that can be recreated by your Local support
Where are you storing the music? which music app are you using?
also check
settings > apps > all > smartconnect > clear data > restart the phone > check again
but again, it seems like hardware related as the FM radio doesn't work, the headphones act as the antena.
Hi @SajjanXperia,
It seems like this is hardware related but try and clear data for the Smart Connect app as uliwooly suggested and see if that helps. You should try clearing data for the FM radio app as well.
Repair the phone with PCC
software repair using PC Companion
Bridge (for Mac)
Alternatives on How to backup Xperias
