E4g seemingly dead on 100% battery
SamHandwich
Visitor
I had just fully charged my battery a few minutes before hand. unlocked my screen and after maybe 3 seconds the screen went black as if i had tapped the power button to lock it again. So i tapped the power button again and nothing. Held the power button down thinking it may have glitched and shut down aaand.. nothin. Plugged it in to charge for ten minutes, tried both again and still nothing. Plugged into my PC which didnt recognise a device, no *da doop* sound, nothin.
4 REPLIES 4
profile.country.PH.title
MarlonUk1
can you try the instructions here? http://support.sonymobile.com/global-en/xperiae4gdual/userguide/Resetting-your-device/
next plug your device to the charger using the wallmount adapter. wait for a few minutes, does it charge up?
Christofer
Champion
Hi @SamHandwich,
I'm sorry to hear this. Slightly_frowning_Face
Could you try forcing a restart using the button behind the back cover?
EDIT: Looks like nolramlb beat me to it. Slightly_smiling_Face
If forcing a reset doesn't help you should see if you are able to perform a software repair using PC Companion.
SamHandwich
Visitor
Thanks guys. I realized that the reset button was an option, but it was a last resort. I have an SD card but nothing very important backed up onto it. Thanks again for the speedy responses.
Christofer
Champion
The reset button will perform a factory reset of your phone. It is more similar to removing the battery out of a device to force a power off. Slightly_smiling_Face The software repair will however erase all data if it comes to that.
