Its not an Mhl adapter just the one cable, one side HDMI the other micro-usb.
Unfortunately, Xperia E4 does not support HDMI or MHL. If you want to share content to a TV, you can either do it via DLNA or screen mirroring.
Thanks for the help, so I would require a smart TV?
It would require a TV that is DLNA Certified or that it supports screen mirroring based on Wi-Fi certified Miracast.
But if you want to cast your screen, a Chromecast might be an option for you:
https://support.google.com/chromecast/answer/6059461?hl=en
Note that, I have never tried it myself but it should work for Xperia E4.
