Problem connecting xperia tablet z with Win7 via Bluetooth. Do I need to download drivers for Win7? Where can I find these drivers from? Thanks.
In which matter are you trying to connect to the PC using Bluetooth? Do you want to browse and move files between Tablet and PC? In that case you should send files from tablet via Bluetooth directly to the PC instead of trying to pair the devices first.
As far as I know there are no other drivers then the ones following PC Companion.
I'm trying to send pictures from Sony laptop Windows 7 to Xperia tablet Z. Thanks.
Is this still a problem ? What exactly didn't work ?
Did you set the tablet to be visible via BT ?
I have the same problem with win 7 64-bit. I am able to install most of the drivers but for some reason it says that the device need troubleshooting. Some of the drivers for the device are not found. I am able to use the PC as a speaker for my tablet but any file operations (moving files between the devices) are not working and are not even shown in the BT menu.
We did try this on my friends similar tablet and had the same results. He is using a different computer so this does not seem to be related to the BT adapter on the computer but either windows or the tablet itself. To my understanding the tablet is using a standard windows BT stack. I have 3 other devices at home that are working perfectly so the problem must be with the tablet
