ARC/ARC S Battery drain problem Solved Finally !!!!!
SOLVED
Auni
Contributor
Finally my ARC S is giving execellent battery backup.
Almost double battery backup:smileylaugh:
Please find this thread below
http://forum.xda-developers.com/showthread.php?t=1413262
Please check this thread from XDA.
Hello guys
Today i am going to give you a very small tip may you people like it ....
i used 2.3.4_283 firmware in Arc for a long time , after that i flashed 42 firmware and feel that its drain battery fast as compare to 283 firmware either you are using you phone or it is in deep sleep mod
Then i flashed 58 firmware and after that 62 firmware but battery drains still fast
then i try one thing on my arc i get the Kernel from 283 firmware and flashed it on all three version of firmwares ( 42, 58, 62 ) and notice that the issue of fast battery drain is solved it is only because of 283 kernel "
now i am using 42 firmware with baseband 64 and kernel from 283 firmware
It does'n matter what ever the firmware you are using or what ever the baseband you are using ....... you need to use kernel from 283 firmware only for low battery drains ..............
i attached kernel from global generic wold 283 firmware also...
How to flash different Kernels
1) connect your phone into fast boot
2) open cmd
3) fastboot devices
(write this command and enter it to check your phone is connected in
fastboot or not)
4) then write this and enter
fastboot flash boot kernel.sin
Done ..........
remember to copy kernel .sin file in that folder from where you are going to launch cmd
I have done this already and my ARC S works completely fine.
This how I have done it
Requirements:
  1. LT18i_4.0.2.A.0.58(2.3.4)_HK firmware (Download from here)
  2. The Kernel from .283 (Download the KERNEL here)
  3. Flash Tool ( Download from here)
  4. WinZip/Winrar or any other similar software.
Steps
Step 1: Download the LT18i_4.0.2.A.0.58 (2.3.4) _HK firmware
  • Unzip the firmware *.ftf file using WinZip or Winrar.
  • You will get a folder like this.
Step 2: Download the Kernel file
  • Unzip the file
  • You will get a file named “Kernel.sin
Step 3: Copy the “Kernel.sin” file
  • Paste the file to the firmware (LT18i_4.0.2.A.0.58 (2.3.4) _HK) folder and replace it.
NOW OPEN FLASH TOOL FOLDER. YOU SHOULD SEE FIVE FOLDERS WITHIN IT.
Step 4: Copy the LT18i_4.0.2.A.0.58 (2.3.4) _HK folder
Step 5: Paste the folder within firmwares folder
Step 5: Click on Flash Tool .exe
  • Click on Advanced from the menu
  • Select bundle creation
Step 6: Click “select source folder” (click on the doted button)
Step 7: Select the folder that you have copied in Flash Tool/ firmwares folder (LT18i_4.0.2.A.0.58 (2.3.4)
Step 8: You will get all the file list on the left side
Step 9: Select all file and click on the “Right Arrow” button.
  • All files should be now at right side.
Step 10: Put anything in this 3 boxes (doesn’t really matter)
I have put following
  • Device:  LT18i
  • Version:  0.58_283
  • Branding: Stock SE
Step 11: Click OK and wait.
Step 12: When you will see the "Finished bundle creation"  message, then the firmware is ready.
Step 13: Check the Flash Tool/firmwares folder. You should get your new firmware “LT18i_0.58_283_Stock SE.ftf” file there.
IF you DO, then just flash your device with this firmware.
All done.
**Important**:
  • I am not responsible if anything goes wrong, so proceed carefully, do not miss any step.
  • I have tested this kernel combination with both 0.42 & 0.58 firmware and it works fine in ARC S.
  • 0.62 firmware (didn’t worked for me)
  • You can easily root this firmware using the zergRush method.
Message was edited by: Auni
50 REPLIES 50
Not applicable
Thank You Slightly_smiling_Face
Auni
Contributor
You are always welcome. Please mark for correct or helpful answer. If the information helps you.:smileyhappy:
slimshaddy
Hero
lol Smiling_Face_with_open_mouth_&_closed_Eyes
you re the author so only you can mark it as helpful and correct answers..he cant see the options...only you can..
so you can mark your's answers as helpful or correct Winking_Face
Auni
Contributor
Dizzy_Face Thanks, never thought of that.
slimshaddy
Hero
hmm Winking_Face
Not applicable
this post is really so helpfull but i have some questions
i am using LT18i with official ics firmware .62
is this method will work nicely with ics .62 firmware
if not then can u gimme download link of official ics .42 firmware ?
Auni
Contributor
Hi Onto,
Unfortunately it doesn't work with 0.62.
Only works with 0.58 or 0.42 GB
Not applicable
oh i understand but there is no solution for ics ?
Auni
Contributor
For ICS there is no patch so far i am affraid.
Not applicable
that means there is no solution for ics , btw then i will flash 2.3.4 again
if u include this kernal.sin file in this firmware and flash , will i face any problem ? http://forum.xda-developers.com/showthread.php?p=21763555
