Low volume 7.1.1
bukos0
Low volume 7.1.1
Hi , after update to 7.1.1   experienced that volume is lower than it was before on 7.0 .  i have done repair via sony companion and still the same.
25 ANTWORTEN 25
grininja
Same here.
bukos0
I found that if u go to settings and do speaker test thru service test with headphones plug in then sound plays alot louder then normaly.
Regards
bukos0
So i am back on 7.0.
Sound is back.
Regards
grininja
Will you please tell me how did you do that? Going back to 7.0 I mean.
bukos0
ok but you do it on your own responsibility. It is very easy
First - thing downloada Flashtool  http:// www. flashtool.net/downloads.php (newest one)
second install it follow instalation step by step .
this is important *after instalation find flashtool folder ( c:/flashtool)
                              *download patch http:// www. flashtool.net/downloads_windows.php
                              * overwrote downloaded file in flashtool folder
now you have the newest flashtool
third - run flashtool exe. and simply follow this https:// www.youtube.com/watch?v=yGc0qNkZ9nw
remember when you will be downloading software ( inbuild program in flashtool) look for 34.2a.269- it is android 7.0 .
You can use any country software onle so dont worry. only difrence will be in time zone or things like 4g instead of LTE witch is the same. And yes all working perfect.
bukos0
and one more thing remember to do factory reset.
grininja
Thank you.
One more question. After flashing will OTA still works? Or will I need to manually flashing everytime an update appears?
bukos0
as far as i know ota works .
bare in mind - http://www.xperiablog.net/2017/07/10/xperia-x-receives-new-update-34-3-a-0-206-with-july-2017-securi...
so they may fix sound.
regards
Nadine2
I have the same problem...
