Camera and flash doesn't work
Nurbanindya0811
Yesterday, i updated  my xperia x . It's a usual update i think. Then, after i restarted my phone, my camera  doesn't work .And it happens to flash too .
Any solutions?
9 ANTWORTEN 9
profile.country.NL.title
Strampke
Can you light the flashlight through the settings menu or with Google assistant by saying: OK Gooogle  and then Turn flashlight on
Did you try clearing data and cache from the camera app through settings->apps->camera->storage
Does it happen in safe mode too?
Nurbanindya0811
I've done everything you said, but nothing happened.
My  front camera is working properly.
4188
Help me please my camera doesn't activity..
Strampke
Try some options:
- can you activate flash through the shortcut menu? (swipe down for settings an d finger on dark part swipe down again, there should be a flashlight symbol)
- goto settings ->applications-> tap 3 dots upper right corner->show system-> scroll to camera-> open and goto storage-> clear cache and data
- does it happen in safe mode too?
- did you install third party apps lately?
manasa2
Facing the same issue. Back camera is not working and flash is disabled.
Noba-30
Looks like it's a factory fafau of XperiaX, I aa hahavintht same problem. I have done everything, evenelost WhatsApp chats in the process
Ismail007
After i have downloaded new update yesterday my rare cam n flash went off
I don't know what is going on with it update of 277mb is also unable to download after 207mb why its not updating i anxious
Strampke
When you have problems with updating then use Xperia Companion
LordTorres
Good day, both cameras and light don’t work, is only show me a black screen and the app close for error. This happened after update android system to Oreo, 8.0.0, Xperia X F5121
Adding information, I restored the whole phone twice, and in the start only light and frontal camera, works, minutes later don’t.
