Sony S Tablet and Connection to a Mac
SOLVED
nirshah45
New
Has anyone had any luck connecting the Sony S Tablet to a Mac?
I have a USB cable and the tablet successfully connects to a PC with automatic driver install, but I can't get it to connect to my Mac. The USB Storage Device doesn't show up and I can't find any Mac drivers for the tab.
Any help is much appreciated.
1 ACCEPTED SOLUTION
Accepted Solutions
nirshah45
New
OK. I found a simple solution.
Android have a File Transfer utility for any Android 3.x device that makes it easy to transfer files to / from your device.
It can be downloaded from here: http://www.android.com/filetransfer/
4 REPLIES 4
profile.country.nl_NL.title
breedBenR
Member
http://www.technipages.com/motorola-xoom-transfer-music-pictures-and-other-files-from-mac-os-x.html
read the above link, for Motorola Xoom, read Sony Tablet S
At this stage, with the tablet being very new, you need to look for a driver for 'Android', the software on the tablet, rather than for 'Sony Tablet S', the hardware, when looking for drivers and connection procedures etc.
nirshah45
New
reza17s
Visitor
I have the same problem with ubuntu/linux system, any suggestions?
profile.country.it_IT.title
brorm2tsmac
Visitor
Maybe this article could be useful to you: Connect  Sony Tablet S to Mac- Play/Watch AVI movie on Sony Tablet S in high  quality
First of all, before you start connecting your Tablet S to Mac, you need to install the Android File Transfer on your Mac which is an application for Macintosh computers (running  Mac OS X 10.5 or later) you can use to view and transfer files between  your Mac and an Android device (running Android 3.0 or later).  Afterwards, mount your Sony Tablet S on to your Mac by using mini-USB.  And then, you can connect Sony Tablet S to Mac successfully.
