WH-1000xm3 unable to pair with LG tv
Herbert_
Explorer
Hello!
Just bought a LG 43UN74007LB TV which should be able to work with headphones via bluetooth. But I can't connect it to my WH-1000XM3. LG support says my headphones must have the A2DP bluetooth profile - but as far as I know that is the case. Anybody any hints on that? Thanks a lot!
3 REPLIES 3
Hi Herbert,
Yes, the 1000XM3 do support the A2DP protocol.
Are they been recognized by the TV? Maybe you've chosen the wrong profile while trying to pair them with your TV.
Cheers
Herbert_
Explorer
Thank you, Peter,
well, where, where would I choose a profile, if you'd be so kind...?
Herbert
Herbert_
Explorer
Thanks, issue is solved by RTFM!
