Sony NWZ-Z1050 Wifi, ect..
profile.country.hu_HU.title
Bjutiii92
Visitor
Hello!
I have a Sony NWZ-Z1050 walkman. Sometimes when I would like to connect to my home Wifi (and use my Internet connection) i can't, because it writes "connected" but it didn't connect. There should be a green Wifi icon, but when it writes "connected" the icon is white. What should i do to solve this problem?
Tags (3)
1 REPLY 1
profile.country.en_GB.title
Convergence
Visitor
Hi first thing to do is check the network settings on the Walkman, does the IP range match your PC also has it got the correct Subnet Mask, sometimes, if a hand shake fails, WiFi products will default to there own IP Address and Subnet mask, leaving you to think its connected.
