NW-A105 All range playback bug ??
Garth12345
Explorer
Hi, Just moved from A45 to A105 and have small problem
On the A45 I used to be able to hit:
Artist-The Who (for example)-All- then when I clicked on the track at the very top of the list the walkman would play all the tracks off all the albums (the who) randomly (shuffle mode on ) until it had played them all
On the A105 when I do this it stops playback when it gets to a different album by the The Who . I have to hit play again for it to continue.
Also if I hit Skip To Next Track while a song is playing the Walkman stops at the beginning of the track , I have to hit play to continue
I have Playback Range set to all
*EDIT*
After a bit more use I can confirm this is an issue when it shuffles from a 16bit track to a 24bit track and vice versa but only on Amazon Echo Dot 4th & 3rd Gen speakers over bluetooth . Does not do this on headphones or an LG soundbar over bluetooth
Tags (1)
2 REPLIES 2
Joe_Dohn
Specialist
According to the Help Guide it should work as you mentioned. So make sure you have the latest software version installed on your Walkman then try that again.
Garth12345
Explorer
Yeah just tried it again after yesterdays update and still the same . Cheers anyway
