Just got these headphones and I am impressed so far, but the one thing i haven't figured out is if there is a quicker way to swithc between bluetooth devices?
I will probably use them most between my Macbook and iPhone and if i want to switch from one to the other, i have to switch bluetooth off on the connected device then manually connect from the other devices.
Is there a quicker way to do this?
If you were using Sony or android devices it would be much easier/faster thanks to NFC one touch listening feature but with iDevices you are stuck. You have to do it manually everytime 😞
