Allow default settings for headphones WH-1000XM4
Please create a feature which allows Ambient Noise Control to be turned off by default (as, I don’t need any noise cancellation/ambient noise control most of the time). I can turn it of manually, but as soon as I turn my headphones back on they have noise cancelling again. Please set a default settings option
1 REPLY 1
Did you check if this can be set to default by using the headphones connect app?
Cheers
