VAIO VPCEH2D0E/B, Ethernet and SFEP drivers install problem
tamvar
Visitor
Hello everybody,
I have the following problem. I have downloaded and installed all drivers from Sony, but in the Device Manager window the Ethernet Controller and Unknow Device shows the yellow bang, as if it were not installed. I tried reinstall them again but its not working.
My other question is, is there a VAIO Win 7 clean install guide or somethinf else that that suggest the correct driver installation order?
1 REPLY 1
Blencogo
Hi tamvar and welcome.
How are you trying to install these drivers?  If they do not have a SETUP file, you may have to install then from within Device Manager by right-clicking on the device and choosing "Update Driver".  You will then need to manually point the installer at the downloaded driver .INF file using the 'Have Disc' method.
:thinking:
