I am facing severe Problem with my laptop.
Modal: VGN-CR19VN/B
The problem is : The system will shutdown the power automatically.
I can’t use this laptop continuously more than an hour or so because it is switching off the power automatically and If I restart by pressing the switch then the system prompts ‘safe mode’ or ‘start windows normally’. And this is happening every time.
thx
sri
Hi sri,
welcome to Club VAIO..
The cause of your vaio shutting down could due to overheating...!!
what is the normal running temperature of your vaio..?
If you're unsure PCWizard is a handy application to check your Vaio’s temperature. To download use the following link: PC Wizard
If your vaio is getting hot you may need to first try clearing the cooling vents of dust with compressed air (you should be able to get this from your local PC shop), holding the can upright give the vents a short blast from a distance of approx. 10cm if you hold the can to close you could damage the fan..
If you do not notice any improvement then your vaio may need to be disassembled in order to deep clean the fan and cooling vents.
