Sony Vaio TZ 31MN/N a little... electric on the lid
AllanSMW
Visitor
Hi all,
Found something strange/worrying about my TZ (and yes it should be being sent off under the rework prog to be checked, but this is different).
With your TZ UNPLUGGED and turned off for a while feel the lid- the square which includes the Vaio sign. Just rub your finger along it, and compare with the outer "frame". Different materials, but feel similar in terms of tactile.
Now plug the TZ in, leave for 30 minutes, you can use it. Now do the same.
Do they feel different? Not sure. Turn the Vaio off, but leave it plugged in, touch again.
Now unplug with it off, leave for 30 seconds and try again.
Am I the only person picking up a small electric charge from the back- even when the TZ isn't on and ONLY when it's plugged in?...
Or is this some touch sensitive sensor which is dimming the lights some where? (has similar earthing feel)
0 REPLIES 0
