problem
natasa222
Visitor
problem
hello from Greece.I have my notebook only for 2 weeks.I have a problem.I pressed a key in the morning and since then the num lock is always on and i cannot write properly anywhere.Especially in the explorer.It indicates that the shortcut button is pressed(S1 and S2).Can I do something about it?Thank you.
12 REPLIES 12
rich912
Contributor
Thank you for your quick answer.The problem is that I pressed a key by mistake.I did not realise which of all Also there seems to be a problem because when i open the internt explorer and press a key it keeps writing until the end of the line.Do you think I should go to the service?How can I enter the registry and fix this problem?
It sounds as though you may have inadvertently turned on an accessibility option such as Stick Keys. If this is the case you can access the dialog box to turn this off by pressing the `shift¿ key five times.
If this doesn¿t work restore your computer to a date prior to this problem occurring ¿ Start > All Programs > Accessories > System Tools > System Restore and select a date when you know that the keyboard was working correctly.
Go n-éirí an bóthar leat
natasa222
Visitor
Geia sou zina!Apo athina eisai e?kai egw...ksereis pou einai to service gia ta vaio?Deixnei na exei trelathei to diko mou.....Me auta ta function keys ti paizete?
Esi eisai euxaristimeni apo to diko sou?
zina
Visitor
ne athina,vasika ke mena stin arxi se kapoia fash trelathike....ekana ena restore kai sinilthe...alla den ime kai poli ikanopiimeni,exi provlima to drive mu poles fores den anigi zorizete poli kani enan periergo thorivo kai mu tin exei spasi telios.den xero pu ine to service,tha to pao piso sto magazi pu to pira gia na ta kanonisun afti....alios tha xestume eki mesa...tosa lefta den lei! ego meno Peristeri,pu esi?
