I can't figure out the correct settings in control panel for the keyboard.. @ sign is shown on the keybord at the right, but I have to press shift 2 to get the character.
Living in the netherlands, using an englisch Vista, dutch (netherlands) - United States-International as default input language (control panel, regional and language options)- which installed keybord or input service do I have to check? Maybe someone can reveal their pre installed setting (since I clean installed..) Gracias!
Hi fldq
Does this link HERE resemble your keyboard layout..?
If so you need to select English(untied kingdom) as your input language
Hi fldq
You're welcome..
