- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I'm setting up a network on my new desktop, and wonder if it's possible to wirelessly connect my VAIO RX624 to my network. This is because my new Windows 8 computer will be the main office computer, and my RX624 will be used less frequently, and hence won't be on all the time.
Thanks for your assistance.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi solushouse,
You can add a wireless adaptor to your PCV-RX624. USB is probably the most simple solution.
Rich
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi solushouse,
Rich
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Rich,
Thanks for the reply. I've ordered a USB wireless network card and look forward to getting it operational. Just wondering if I can use a similar arrangement with a printer that currently doesn't have a wireless facility?
Many thanks indeed.
Pauline.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Pauline,
Assuming that your printer is not either a network printer connected to the router via Ethernet cable or has Bluetooth or wireless capability then adapting it will probably be difficult.
However once you have wireless networking on both computers you can set up a printer share on the computer that is connected to the printer thus allowing the other machine to print through the network. This does require both computers to be turned on if you wish to print from the machine that is not directly connected to the printer.
To set up printer sharing open Control Panel on the computer connected to (and having the printer drivers installed) > Printers > right click the printer name and allow sharing.
Then on the other computer open Control Panel > Printers > and click ‘Add Printer’ > Select ‘Add a network, wireless or Bluetooth printer’. This should then identify the printer that you have allowed to be shared.
Depending on the operating systems you are running the procedure may vary slightly and you may need to first enable printer sharing within Network and Sharing Center.
Rich
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Rich,
Just wanted to let you know that my USB wireless network gadget arrived, and it works perfectly. Thank you very much for your help. Also, thanks for the advice about the printer too, which I managed to set up.
Regards always,
Pauline.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Excellent. You’re very welcome Pauline.:smileyhappy:
Rich
