Hello Guys,
I have a problem after re-installing the OS. The battery checker is telling that , "Your battery is not connected properly, Please click OK to hibernate". But battery is properly connected and sufficient charge is available.
What might be the problem?
Message was edited by: Arulsubramaniam
Solved! Go to Solution.
Yeah. I have re-installed the OS .
As I have re-installed my OS, I have to install all VAIO softwares including VAIO power management, Battery checker. So I did.
Thanks for giving a hint.
ISBmgr.exe was running and the problem was due to that only. I closed that process. Now the Laptop is OK.
I'm using the same original battery.
But I'm curious to know, what is the problem in re-installation? Don't I have rights to do it?
In my point of view, Re-installation should not affect software behaviour. Am I right?
Have you reinstalled the original Sony operating system or have you installed a retail version?
Have you reinstalled Vaio Power Management?
Have you reinstalled the Battery Checker utility?
Do you have a process 'ISBMgr.exe' running at starup? Check in Task Manager.
Are you using the original battery?
I don't know what has happened - a full system recovery should reinstall all the software properly.
I just know that ISBMgr causes the message.
You could try asking Vaio Support but I guess it is a one off - at least you will know what to do next time!!!
Yeah.. It is good to know that, even well known brand has some unknown exceptions..
It will be better, if they fix it
Anyway, thanx for replying.. Meet you soon in next post .
