HI EVERYBODY
I HAVE VAIO FS 215B CENTRINO 1.73
AND INTEL 915G/ML (WHATEVER LIKE THIS )
512 MB RAM
AND THAT CARD CAN BE 128 MB (SHARED)
ALSO STILL USES 8 MB
HOW CAN I ADJUST TO 64 OR 128 MB
CAN YOU HELP ME TO SETUP VIDEO CARD MEMORY
THANK YOU
BIOS is the magical word. Press and hold F2 if you see the VAIO-logo, if you start your VAIO.
Caps Lock
I TRIED (BIOS MAINTAIN) THAT BUT THERE IS NO OPTION TO CHANGE GRAPHIC CARD S MEMORY ..
ANY ALTERNATE TO SOLVE THAT ?
THANKS FOR ALL OPINIONS
Same problem on a VGN-FS215E!
Shared Memory is at 8 MB and not changable.
Bios offers no option to change it.
Seems to be a new fault of the FS series.:smileycry:
e-support answer
*** NOTES 13-Jun-2005 Action Type: Info
Thank you for contacting us,
your vaio notebook has 64MB dedicated memory, this means that the Graphics Chip has 64Mb memory of its own, and it has an other 64Mb dynamic memory, which can be taken from the 512MB memory which the vaio contains,
if you are running heavy graphical applications, the vaio automatically uses some of the "standard" memory as video memory, so your vaio is using 64MB video memory and 512MB "normal" memory when you are working in a non graphical environment, and 128MB video memory and 448MB "normal" memory in Graphical environments
does it mean i can't itervene to graphic card
I THINK ITS NOT GOOD BEC. SONY ADVERTISEMENT IS THAT NOTEBOOK HAS 128 mb INTEL915 GME GRAPHIC CARD
......................smells monkey business................................
But why the graphicship can only recognize 8MB?
e-support answer
