Hi!
Have a problem with the display in that everything is large - fonts, icons etc - and is a little blurred. All the sharpness has gone from the display and many screens now won't fit properly. I don't use a screensaver as I understand one of those has caused a problem in the past, and have checked the display settings on the personalise desktop option which are on the 96dpi. Even after restarts it still persists. Any ideas?
Jeraldo
have you tried checking your display settings to see if your resolution setting is on high or low if its on low or the middle try sliding it to high and click apply
Good Idea Tellyaddict
Right click a space on desktop - personalise - display settings
Thank you both - worked first time!! I'm very grateful.
Jeraldo
Glad its sorted
