CPU upgrade in Vaio VGN-NS10J (QX9300)
SOLVED
david1519
New
I have Sony Vaio Vgn-NS10J a bit old laptop. I changed the cooling manually to water-cool system, because the original cooling crashed.
My idea is to change the inside T9600 CPU to QX9300 for more computation capacity.
What do you think about this? Is it possible, will it work?
(Maybe I have to change the charger for more energy?)
Waiting for replies,
Thank You!
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.IT.title
Marino.Manolo
GM45 is your Chipset and HERE the compatibility list.
Manolo
2 REPLIES 2
Marino.Manolo
Manolo
david1519
New
I see! There is QX9300 in the list! Thank You so much for this information! ^^
