Hi, I’ve noticed that if I don’t enter my password immediately and open Windows my C2S cannot find a wireless connection when I go to “connect to a network” to check it is empty of connections but if I close down restart and open Windows straight away it finds and logs on to my connection fine and sees a number of available connections that are available in “connect to a network”.Please help,Co2laser.
Hi co2laser
Does installing the Wireless Switch Setting Utility Update Version 3.6.01.20140 help.?
Update can be found HERE
Hi Thalamus, As you suggested I’ve installed the utility and it seems to have worked. Thank you for your time and help. Regards, Co2laser.
You're welcome co2laser..
