Hi
I wonder if someone can remind me of the hotfix details for the camera capture utility which is playing up again - only works once on Skype or the CCU. Have had the problem in the past and it's reocccuring as I had to reinstall everything a while ago. I remember there was a hotfix or other solution which sorted the problem before but can't find it anywhere now ...
Running a Vaio VGN AR 31 M.
Thanks
Jeraldo
Hi Thalamus
Thanks - as ever! Works fine now.
Jeraldo
You're welcome Jeraldo..
