Xperia X8 2.1 update
Nicht anwendbar
I have a sony ericsson xperia x8 with the new 2.1 update, i heard you can send files via bluetooth with the new update but when i try looking for options on how to send it..i can't..
Can someone explain how to send files via bluetooth?
suze
Alter Hase
On an image when viewing in the album, tap on the envelope in the top left of the screen and select bluetooth, if you bluetooth is not already on you will be given a prompt asking if you want to turn it on.  Then tap scan for devices for a new device and pair in the normal way or tap on any device that says paired but not connected.  Don't worry about the not connected thing, it will still send across the image. The receiving device should then get your image.
On a music track tap the top right icon to bring up a track list, and then long press on the track you want to send.  You then get two options, Send or Delete.  Tap send and tap bluetooth and follow the same proceedure as above.
suze
Alter Hase
Nicht anwendbar
Thankyou so much :smileygrin: this solved it.
