Xperia SP Battery Life
SOLVED
nlk
Visitor
can you please tell me what is the standby battery life of Xperia SP.
my phone only shows 1 day and 10h stand by time when its 100% charged. but in the sony website they say it has more than 600h of standby time..
in normal usage it very dificult keep 1day battery time of my phone.
1 ACCEPTED SOLUTION
Accepted Solutions
Ashroft98
Enthusiast
It will create a new pattern.Xperia's Stamina Mode always learn Grinning_Face
17 REPLIES 17
blizzard
Visitor
is 600 hrs withouth a sim card, no internet connetion, nonothing. all manufactures say theyr cellphone last for houdrets of hr but infact , if u'r phone lasts for 1 day of havy using (and my xperia sp dose)  it's very good
profile.country.RO.title
_alexdon_
if you really want to see,remove your SIM,put the phone on airplane mode and leave it like that,without any other connections.
alexdon
Ashroft98
Enthusiast
No need to worry brother.
The estimated standby hours is not 4 days or 6 days as it should because your phone have learned your battery consumption pattern thus giving a quite accurate standby hours according to your way use of power consumption.
But in any cases,you could refresh the phone's power consumption pattern.
Simply:
Go to Settings > Apps > Swipe to the most Right > and search for "Eco Mode Controller".Press it and then Clear Data for it.It won't affect anything in the system only the phone's power consumption is refreshed.
Hope it helps :smileyyahoo:
nlk
Visitor
actually its normal ussage. wihout playing too much games, no GPS, no mobile data, no wi-fi, NO NFC or blutooth etc. thats how im using that. and its very diffiult to keep 36 hours battery life
_alexdon_
It is obvious you will not get 600 hours,that is experimental,but you may get somewhere up to 200,because even looking at the clock or turning on the screen drains.
alexdon
Ashroft98
Enthusiast
Yea,have to agree with that.Power consumption is even more if you use Mobile Data compared to WiFi.
nlk
Visitor
does it remove poweer usagee pattern forver? or will it make a new power usagee pattern after clearing Eco mode controller
Ashroft98
Enthusiast
spixel
Visitor
Estimated standby time should be renamed estimated battery life, because that's what it really is.
Don't be concerned what it says you 'will' get. Be concerned with what battery life you actually do get.
If you think your battery is draining too fast you're not the only one to think this, I also have battery problems with my SP. Please post a screenshot of your battery stats just before recharging.
