I have a problem with my new Xperia Ray.
I've got it from a friend since he has bought an iPhone insted.
The phone used to work perfectly when he had it, but with my SIM-card in it, there is no network.
I get a message saying something similar to "Network not supported by your SIM-card".
What does this mean... ?
Is it SIM-locked, or does it need to be repaired or something like that?
Thanks in advance.
-Mike
Solved! Go to Solution.
Hi Mike Ransby
To reset your APN, click "MENU" on front of phone, click "settings" on the bottom right of the screen
click "Wireless and Networks" at the top of the screen, Click "Mobile Networks" at the bottom of the screen,
Click "Access Point Names" at the bottom of the screen.
Click on the APN ,Click "MENU" on the front of the phone and select "Delete APN" on the screen,
To input a new APN click "MENU" on front of phone, click "settings" on the bottom right of the screen
Click "Access Point Names" at the bottom of the screen. Click "MENU" on the front of the phone and select "New APN" on the screen,
Enter details of network settings below and then click "MENU" on the front of phone and "Save"
You need to known the APN setting, follow the link below
http://www.filesaveas.com/gprs.html
Hope this helps, sorry for the late reply was working from 7am
Hi Chardeen,
Once again, thanks a lot for your time.
And I think you're right..! Is seems like the APN settings are the big problem in my case.
I've followed your instructions. First I tried to delete the APN setting, by choosing:
MENU --> SETTINGS --> WIRELESS AND NETWORK --> MOBILE NETWORK --> ACCESS POINT NAMES...
But when I choose Access Point Names, the screen is totally empty.. Nothing to choose..
Only thing visible is the clock in the right corner, and the title "APN's" in the left corner...
I've tried to click the title, but as I expected, that didn't have any effect... So only thing I could do, was go back..
Maybe that is a sign that the phone is broken somehow?
Once again thanks for all the time you've put in this. Really appreciate it.
strange.... is that menu completely empty. can you post some screen shots of this menu.
how to take screenshots(if u don't know)
if you're in GB hold power button n take a screenshot
if you're in ICS hold power button and volume down button together and take a screen shot
if you are looking for the networks ,MENU --> SETTINGS --> WIRELESS AND NETWORK --> MOBILE NETWORK -->Network operators
Thanks for your reply, and for the info about screenshots.. Didn't knew that
I've managed to take a screenshot now, but don't if it's still interesting, since I've found a solution for the missing choices in the APN settings.
It seemed there was an new update for Android, which actually solved that part..
Still can't find my network though
Hey Chardeen,
After updating Android on my phone, I'm finally allowed to type in the APN Settings..
I found the exact settings at my phone companys webpage though
just to ensure it's the right one..
But unfortunately that didn't solve the problem. Still can't find my network, and when I try to connect to some of the other network, it still reply something like "This network is not supported by your SIM-card"
I've also tried testing the SIM-lock code once again, but the result is still the same, with the question marks (?) and no numbers...
This is really weird..
i wonder how your friend used that phone in the first place.
did you changed any setting after getting the phone?
do you use a sim card from same servise provider which your friend used before?
Hi MikeRamsey
Sorry to hear that you are still having problems with the phone. Its really strange and I don't what to try next.
Try to repair the firmware by using either Sony update service or pc companion, just in case the firmware has become corrupted.
You will needs to reset your APN.
Finally make sure your signal was set to WCDMAprefered/GSM.
click "Network Mode" and select WCDMAprefered/GSM.
Incidentally what SIM are you using and what SIM did your friend use. If its possible can you get a SIM from someone and try it just incase its your SIM.
Hope this helps.
Pavan_Hyuga.. I've been thinking the exact same thing..
But the day I recieved the phone, I could see some photos saved on the memory card, taken the exact same day.. That's kind of why I'm thinking that the phone must have been fine then..
Also why I doubt that the phone could even be broken at this point.
I was kind of hoping that any of you, could tell right away that the phone was either SIM-locked or Hardlocked.
But to answer your question I use a SIM-card from a different service provider, but still use the same network, called TDC with 3G.
And when I first found out that I couldn't connect to my network, I reset the phone to factory settings.
But same result.. Really anoying!
can you pls lend a sim card from someone, (from same service provider which ur friend was using in your phone) and check whether it's working
