W205: playing music via bluetooth stereo?
SOLVED
Not applicable
I want to buy stereo bluetooth headphones. Something like this:
http://www.amazon.com/Motorola-98689-Bluetooth-Stereo-Headset/dp/B000BBE9C8/ref=tag_cdp_ptcl_edpp_ur...
Will this work with the W205? Do I need some kind of special software? I want to be sure that it will play music via bluetooth before I buy the headphones.
Thanks a bunch!
1 ACCEPTED SOLUTION
Accepted Solutions
Dr_Chris
Champion
According to your phone's specs, it supports A2DP stereo Bluetooth, which is what you need to use this headset.
4 REPLIES 4
Dr_Chris
Champion
Not applicable
Thanks doc! Slightly_smiling_Face
So I basically connect the headphones with the phone via BT, play the music and I'm all set?
Dr_Chris
Champion
Yes, that should be it.
Not applicable
I am sorry to say that SE W205 does not support most of bluetooth setreo headsets. I tried several, including MW600 and it did not work. I have yet to find one that works with W205.
