Timescape is gone
SOLVED
zzsetozz1
Visitor
Timescape is gone
Hi, my timescape is gone from applications, so how can i get it back.
not from the widgets only but all of it.
is there any way except installing the whole rom using SEUS.
1 ACCEPTED SOLUTION
Accepted Solutions
Johan
Master
Unfortunately you will have to reinstall the software via Update Service, because there is no separate APK for Timescape that you can install.
3 REPLIES 3
Annie
Contributor
If the application has been deleted, there is no other way to get it back unles, as you mentioned, to install the whole rom using SEUS.
zzsetozz1
Visitor
you mean i can't install it using apk or push it to the phone, no other way.
Johan
Master
