smart led
antonidas
smart led
dear sony and customers.
İ have an idea.
My xperia sp's led light goes green when charge reach %90.
when charge reaches %100 it still green.
I cant understand the difference.
My idea:
When phones charge %100 led light should blink or change its color.
antonidas
light manager app solved my problem.
i saw it on sony select and it works perfect.
you can set light %0-99 red and %100 green or another color. I set yellow for example.
16 ANTWORTEN 16
Uliwooly
That's normal behavior, once it reach 90%-100% the LED will turn green, once it reach 100% the screen will turn on for few seconds.
antonidas
it's not enough.
When charge reachs %100 phone should give clear signal.
sony can do this with simple software update.
I dont want to check the phone constantly.
When led turns green charge may be %90,%93,%98 or 100.
how can i know the exact percentage.
i want this:
when charge %0-89 red light, %90-99 green light, %100 teal light or different color.
sony should add this feature
Danial-mach1
Alter Hase
You can use 3rd party apps
Light flow and illumination bar
antonidas
thx,
I am trying light flow now.
antonidas
i installed these apps.
But there is a problem.
I installed third party app and i assigned specific color for full battery, but when battery reached 100 led light was still green.
I look options/led lights and there is no option to change full battery color.
3. parts app works like this:
First you have to close normal led light color.
Than you should enter 3. party app and assign different color.
For example if you want to change message led color with 3. party app.
First you should close notification color from default options menu.
Then you can select different color from third party app.
In default options menu you can not select full battery led color.
but it fixed green color.
3xperia
On STAMINA MODE
0% - 89% > Red light.
90% - 99% > Green light.
100% > the light goes OFF automatically.
antonidas
for example lets focus missing calls.
You have default led light options and you have a third party app.
If you chose red color from default menu and you chose purple from third party app they overlap. In this situation led light's color will be red.
You have to chose none color from default menu than you chose purple from third party app and it works as you wish.
But in my situation.
I cant chose none color in default menu. Becasue there is no option for full battery color.
antonidas
i think sony should give us this option.
3. part apps dont work properly and third party app means ram consumption.
3xperia
@ Antonidas
Lol you're so complicated. Just turn on the STAMINA MODE when you charge your phone, so you will notice when it's full.
All I want and the most important is Sony fixes the bugs, especially the grainy and blurry camera on Z1 and SP.
