my xperia sola battery lasts for only 18hrs with minimum or no use.i have noticed in battery usage info that android os drains around 30-50% battery.and after doing some research on xda i came to know that this is a software issue which was also present in xperia s.is there going to be a firmware update for the xperia sola to reslove this issue?.
Solved! Go to Solution.
I have same problems with others when my battery reaches 30% or less than its getting drained already and when i turned on my phone its already 0%. I do update my software it doesnt change its problem
Try to repair via sony update service:
http://www.sonymobile.com/gb/tools/update-service/
If not helping,visit a sony service:
http://www.sonymobile.com/global-en/support/contact-us/
I've also been getting this battery suddening draining to 0% problem for the past month or so.
My Sola has just gone on about 18 months old. From fully charged it will drain down to 50, 60 or 70% or so then if I am using google maps or browsing the web it will rapidly fall to 0% and shut down.
Often when I restart the phone it is back up at 20 or 30% despite being at 0% a minute ago. Sometimes it turns off again and stays at 0%.
I'm wondering if it is a battery problem or what?
My phone says it is running the latest software and there is no updates.
i have brought xperia sola on january 2012, for last 2 years if works excellent and without hang. but now after fully charge the battery at night it draing by 50 % in morning with with no use. also phone gets hang frequently.
Earlier this was not occured.
