my phone wont restart after updateing
SOLVED
Not applicable
hi
my phone does not restart after the latest android update?
its been nerly 12hours and all its doing is turning on then off, i cant do anything with the phone, it dosnt let me turn it on or off, i cant do nuffing.
am i ment to have a memory card in for this?
thanks
kent
1 ACCEPTED SOLUTION
Accepted Solutions
gwhispererz
Champion
Actually you can, start up PC Companion (but don't connect phone first). Anyway, here is a link to SE Update Service, http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/xperiax10?cc=sg&lc=... Good luck.
5 REPLIES 5
gwhispererz
Champion
Try removing battery, put it back again and reboot phone. If that did not work, do a software repair with either PC Companion or SE Udate Service. Good luck.
Not applicable
ive tryed that, but when i put the battery back in it does the same thing, just turns on and off. i cant get it to conect to the pc companion as phone does not turn on
kent
gwhispererz
Champion
Not applicable
thank you so much!!!
kent
gwhispererz
Champion
Welcome. Glad you have your phone working again. Grinning_Face
