Hey guys ...
Does anyone know how to install the old versions of android like 4.1 ?
Solved! Go to Solution.
Now, that is the answer I was looking for. Simple "yes" or "no".
I did a security copy using the PCC, if I restore the copy I will get only the personal data or also the old Android version?
If you backed up,you will get only files back(not software).
Hi woodsidebeer
Why dont you try doing reset factory settings , which ironically has solved many problems with hanging , ram space and many, worked well for mine, even i had faced the same issues when i updated.. now its working fine without glitches.
download the firmware u want then flash it to ur phone easily...
