How to get rid of this Data usage warning notification? :(
Karan_wolverine
Data usage warning is showing in my notification bar and i didn't found any way to turn it off, its very annoying, waiting for suggestions
kafkas
Firstly you need to enable data transfer then you will be able to set or remove data usage warning and limit. Or you can change starting date of data usage.
16 ANTWORTEN 16
Uliwooly
settings > data traffic > uncheck the data limit or set it higher
is Sony spying on users in this forum?
http://talk.sonymobile.com/thread/60197
Don't forget to mark the Correct Answers & Helpful Answers
UNRELATED topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
Karan_wolverine
thanks for the reply, can you specify the path properly? coz there is no option called data traffic in settings, Data usage is there. There is no option in this section  to either turn it off or to extend Slightly_frowning_Face
Uliwooly
typo
data usage
you should be able to see
Set mobile data limit
can you post a screenshot of the message?
Karan_wolverine
Even if i open the options in this page there is no way to clear this Slightly_frowning_Face
Uliwooly
ok that's odd that you don't have that option. can you post a screenshot of the warning? I'm starting to think that it might be a network/carrier setting.
Karan_wolverine
Hi, its not a network problem. Below is the screenshot of that warning, when i click on it, it takes me to same settings screenScreenshot_2013-01-02-12-08-51.png
Tapping on that notification will take me to below screen same as in settings
Uliwooly
do you have a data limit (2GB, 3GB, 5GB data plan)?
Karan_wolverine
yea, 1GB pack
Uliwooly
there you go, that's why you are getting the notification, it seems that you are either at or close to your 1GB data plan limit. so it is a notification set by the carrier, is your phone network branded?
