how to enter unlock code in xperia VL
SOLVED
ali2300
Visitor
hello guys thank you again for the help you provided me with before
i bought unlocking code for my xperia VL ( sol21 ) locked to AU from japan and i cant see the box where to enter it
when i put a sim card it supposed to ask me for the unlock code but instead it tells me " no sim card could be reconized "
how to enter the unlock code ?
regards
1 ACCEPTED SOLUTION
Accepted Solutions
ali2300
Visitor
i put a code *#*#7465625#*#*  then you go to network and you get asked to enter the pin code Smiling_Face_with_Sunglasses  and it is unlocked now
but it didn't work on Z1 so i am still on it
13 REPLIES 13
profile.country.RO.title
_alexdon_
The unlock box should pop up if you insert any SIM in your network locked device.
alexdon
ali2300
Visitor
exactly, it should but it doessn't. here is a picture of what i get when i insert a sim card
http://prntscr.com/6n7mtt
and that is what i get in all the sony i bring from japan actually, Z1, VL, IS12S
any ides on how to solve this for the VL (sol21)
_alexdon_
Is the microSIM trimmed ?
alexdon
ali2300
Visitor
the sim card works perfectly on other devices i checked and i use it everyday but when i put it in SOL21 or  SOL23 i get that message
i also tried different sim cards not only mine, and the result is the same
_alexdon_
No,sorry.In this case,you should get assistance from a sony service:
http://www.sonymobile.com/global-en/support/contact-us/
alexdon
ali2300
Visitor
ok i solved it Slightly_smiling_Face thank you
_alexdon_
How did you do it?
alexdon
ali2300
Visitor
_alexdon_
Wasn't this code for Samsung devices only?
alexdon
