Help upgrading to 2.1!!
SOLVED
Not applicable
I just received my X10A in the mail today...I went online and to Sony Ericsson's website and followed the instructions for upgrading to Android 2.1; downloaded PC companion...but it says my phone is 'up to date'.  I am still running on 1.6. I then You-Tubed instructions but holy crap....its really complicated...and i can't get it to work.  is there an easier way...or would someone be able to...how should i say...dummy-down some instructions for me? :smileygrin:
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
once you download
X10a_2.1update1_r2.1.A.0.435_Generic.ftf
put it insdie
     FlashTool
               Firmwares
12 REPLIES 12
Not applicable
Hi there.
I found this guide a while ago, translated from swedish to english via google but still easy to follow: http://talk.sonyericsson.com/thread/8020
Good Luck!
Uliwooly
quite simple, you need to download two files
1) Flashtool (NOT the flasher)
2) the firmware
both from this link http://forum.xda-developers.com/showthread.php?t=920746
install FlashTool
inside there will be 5 folders
Custom
Drivers
Firmwares
Loaders
X10Flasher_lib
put the firmware file inside "Firmwares" folder
click on X10FlashTool
click on Flash
Press Okit will ask you to connect your phone on Flashmode (turn off your phone, press the back button, then connect the USB) press OK
Uliwooly
you can download falshtool 0.2.8 or any version and the firmware download this
X10a Generic
Generic version 2.1update1 build 2.1.A.0.435 (MD5 : 0C67A08A4B120EBA87E395865F431E81)
Uliwooly
after you install 2.1 on your phone get this apps
on your computer
http://forum.xda-developers.com/showthread.php?t=826311
Download
Gallery_X10
Music_X10
They were supposed to be included with android but Sony Ericsson removed them so there wouldn't be competition to their Mediascape
I sugest you create a file on your SD card so you can put this apps together and others that you will side load, you can call it APK or something like that
make sure that you go to
Settings
          Applications
                         and that Unknown sourcess is selected
Uliwooly
Not applicable
Not sure if you still check this but I ran into a problem with flashing the phone and I believe I bricked it. It went thru the flash just fine, it restarted showed the camera with the blue arrow and now all it does it restart itself. Any help would be appreciated.
Uliwooly
just start all over and it will be fixed
Not applicable
Uliwooly...thanks for the quick response.  I'm still having issues (i swear to god i'm not an idiot...it only appears that way lol).  I went to the link you gave me...downloaded this flash tool:
Download FlashTool version 0.2.9.1 Beta :
http://www.multiupload.com/7H4JT35B6G (MD5: 4C370DDC5B6D40F96CA00D856019B19F)
Then i downloaded this firmware file:
X10a Generic
After i downloaded/extracted, the 5 folders you listed all appeared along with the X10FlashTool.  I'm uncertain which specific files to move into the firmware folder (currently empty).  Everything i try to move in there.....after i open the flash tool...and run as an administrator....nothing appears in the file list....no matter which folder i select.
Am I missing a download...or am i really just an idiot? lol ahhhhh help please!! (i attached a pic of my desktop so you can see what i'm seeing (or not seeing).
Files in Custom, Firmware, X10Flasher, and Driver folders.  Nothing in CustomRoms folder.  In the middle picture…that’s the Flashtool….when I select the source folder….nothing pulls up…in any folder I select.
Uliwooly
once you download
put it insdie
     FlashTool
               Firmwares
