Hi;
I can't turn off my xperia v (android 4.1). When i press the on/off button in the side it shows 3 choices: Turn off, airplane mode and screen shot, but when i press the first one the phone restart instead of turning off. Plz help
Solved! Go to Solution.
No,you do not need to root.Download sony update service and repair:
http://www.sonymobile.com/gb/tools/update-service/
Are you volume buttons working well?I suggest you try power button+vol up until the phone vibrates.
Noting happened, volume keys work well.
Boot your phone in safe mode,see if it works:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
Thanks but it's not working..Do you know any application to shut down without rooting?
So holding power and volume up for atleast 15 seconds gives no vibration - 1 is a reset - keep holding and 3 is a shut down
Thanks friend, it works well
Anytime.
