CAMERA DOESN'T WORK AFTER UPDATING MY XPERIA S
SOLVED
harrem
Visitor
after i update my xperia s. hte camera doesn't work and it prompted me "error" "camera not available"
i try to update again but still the same... then i try again then i click repair but it is still the same... then i follow your instructions:
"Settings > Apps > All (tab)." and all apps are on. i open again the camera then error again and camea not available... hope you can help me about this problem as soon as possible... needed your reply sir, please
thank you...
1 ACCEPTED SOLUTION
Accepted Solutions
Thommo
Try Settings - Backup and restore then choose Settings reset, If that doesn't work then try PCC to run a repair if you have already tried PCC then try using SEUS or SUS found here http://www.sonymobile.com/global-en/tools/update-service/
9 REPLIES 9
Thommo
harrem
Visitor
the link you gave me http://www.sonymobile.com/global-en/tools/update-service/
i download it and install.. i follow all the instruction carefuly rather it's still the same.... my camera in my Xperia S doesn't work.
any help sir you can give to me?
thank you for the considerations
Uliwooly
backup everything on a PC (music, pictures, videos, etc) then reset the phone
Settings > storage > Clear internal storage
then
turn off your phone > press and hold power & volume up for 10 seconds, until the phone vibrate 3 times, connect your phone to a wall charger and let it charge, it will take several minutes to turn back on
Uliwooly
You can also try
Settings > apps > all > camera > clear everything > restart your phone > check again
If this doesn't work then follow my above suggestions
harrem
Visitor
it's still the same.... nothings happen sir Slightly_frowning_Face all i followed carefully all the instructions but no good outcomes.... what can i do now?
piotrom87
Visitor
I have the same problem on Xperia P.: http://talk.sonymobile.com/t5/Xperia-P/Error-Camera-not-available-after-update-to-6-2-A-1-100/m-p/33...
A week ago i've sent my phone to Sony Repair Center and today it is back.
On the 'repair report' I've got ONLY  'Software Update' (earlier I had 6.2.A.1.100 and now it's also 6.2.A.1.100) and of course problem still persists :smileysad:
Sony what can we (or you) do to fix it?????
harrem
Visitor
sad and sad everyday... no one can help us here... omg
piotrom87
Visitor
Few days ago I've sent my handset to Repair Center again.
On 'WWW repair status' I can see: replace motherboard.
I hope that will fix my problems with Xperia P Slightly_smiling_Face
majid_asgari
Visitor
I have found a (dummy) answer!
just goto Settings > Apps > All
and disable Xperia camera add-ons
My camera is OK after that!
