Battery drains too quick % phone heats up.
Currently on OS JB 4.1.2
Plz help
Solved! Go to Solution.
The phone will get hot, that's normal, the more you use it and/or the heavier apps that you run the faster it will get hot and the faster the battery will drain, if you sync multiple accounts and/or services it will drain your battery faster, this is through to all phones
Its down to 59% from 100% 1 hour of gaming.
10 min browsing, Wifi
That's normal, keep in mind the size of the HD screen, how bright it is, plus games will drain your battery quite fast, wifi will drain your battery fast
Should I use task killers & Ram cleaner or battery savers etc ?
That's a terrible idea, battery apps, taskillers, task managers, antivirus, ram apps, booster apps, etc will drain your battery even faster, as this apps will be running in the background the whole time also, they are known to create other issues, just stay away from those apps
