Comparte tu experiencia!
Good day.
About a month ago there was a problem - when I click on Settings through the menu or through the notification panel, I get a window with the error "Unfortunately, Settings has stopped". Therefore, I can not get into the settings in any way.
A few hours later, the settings were re-enabled, but then stopped working again.
I tried to get there through the safe mode and to no avail.
I also tried to reset the com.android.settings application data with adb (adb shell pm clear com.android.settings), the data was erased, but the settings still do not work.
Then I decided to make factory reset using Xperia Companion. Everything again began to work, but after a week, the problem reappeared. What should I do?
Hello @vvi7ch and welcome to the community!
Did you backup and restore apps and/or settings when you repaired software using Xperia companion? If you did, then I'd suggest that you redo the software repair using Xperia Companion, and exclude those from backup and restore process.
