MAC version: https://youtu.be/iV75DJcsK-E
Here is the advanced user guide for the Sony Channel Editor.
There are two methods you can use when searching for channels. You can search purely by the channel number using the small number box in the top-middle section of the application, as well as searching by text (such as channel name) using the search box at the top left-hand side of the application.
| Figure 12: Search boxes |
Numerical search
Enter the channel number you wish to find (e.g., ‘001’, ‘2’, ‘07’), then press Enter as shown in Figure 13.
| Figure 13: Numerical search |
Text search
Enter the channel name you wish to find (e.g. ‘ZDF HD’) and press Enter as shown in Figure 14.
| Figure 14: Text search |
If you want to position HD channels at the top of your list, please click HD CHANNELS FIRST button on the left-hand side menu. All HD channels will be listed starting from position 1 as shown in Figure 15.
| Figure 15: HD Channels First |
Please note that HD channels may or may not have “HD” term in their names.
Delete is used to remove selected TV/Radio channel(s) from your current loaded sdb.xml. To delete a single channel, please click on the channel you wish to delete as shown in Figure 16.
| Figure 16: Selecting a channel |
TIP: To select multiple channels hold CTRL or SHIFT on your keyboard
Then please click DELETE from the options panel on the left-hand side as shown in Figure 17.
| Figure 17: Clicking delete |
In order to finish the delete operation, please click OK as shown in Figure 18.
| Figure 18: Dialog box |
The selected channel has now been deleted as shown in Figure 19.
| Figure 19: Channel list with deleted channel |
You can move single or multiple channels by selecting the ones you wish to move and dragging them to a new position. This makes use of the conventional drag and drop method which allows you to reposition the channels in your list easily and quickly. This method can be used for both television and radio lists.
TIP: The drag and drop method is not suitable for middle positions between selected channels.
Select the channel(s) you wish to move as shown in Figure 20.
| Figure 20: Selecting channel(s) |
Drag the selected channel(s) to a new location of your choice as shown in Figure 21.
| Figure 21: Moving channel(s) |
The channels are now in their new positions as shown in Figure 22.
| Figure 22: Channels in their new positions |
Sort Alphabetically
In order to sort your channels in alphabetical order, please click Sort Alphabetically.
| Figure 23: Selecting sort alphabetically |
The channels have now been sorted alphabetically as shown in Figure 24.
| Figure 24: Channels alphabetically sorted |
Sort Numerically
If you click Sort Numerically, your channels will be sorted in numerical order according to their channel number.
| Figure 25: Selecting sort numerically |
The channels have now been sorted numerically as shown in Figure 26.
| Figure 26: Channels numerically sorted |
Favourites can be added to four favourites lists. A television channel or a radio channel can be added to a favourite list.
The favourite buttons are displayed at the bottom of the application screen.
| Figure 27: Display Favourites 1, 2, 3 and 4 buttons |
Adding channel(s)
To add a single channel, please click on the channel you wish as shown in Figure 28, and select the Edit Favourites button from the options panel.
TIP: To select multiple channels, hold CTRL or SHIFT on your keyboard.
| Figure 28: Selecting a channel and Edit favourite button |
The dialog box "Add to Favourite" will be displayed to indicate which favourite list to add your selected channel(s) to.
| Figure 29: Dialog box displayed when ‘Edit Favourites’ button selected |
Channel(s) can be added to one or more favourite lists, by simply choosing a favourite list number and clicking OK.
| Figure 30: Dialog box to select the favourite list user would like the channel to be added to |
Added channels to a list can be viewed by selecting a favourite button from the button of the application window as shown in Figure 27. A list of the added channels would be shown as in Figures 31 & 32 below.
| Figure 31: Channel added to 'Favourites' list – 1 |
| Figure 32: Multiple channels added to 'Favourites' list – 4 |
Please click the BACK button to return to the application main screen
Favourites can be removed from four favourites lists.
Select a favourite button to display all channels added to the selected favourite list.
| Figure 33: Displays all channels added to the selected 'Favourites' list |
Select the channel(s) you would like to remove from the favourite list.
| Figure 34: Displays selected channel to be removed from the selected favourite list |
Unselect the favourite list number to remove the selected channel from the favourite list.
| Figure 35: Unselect favourite and click OK |
To view the updated favourite list, please click on the favourite button of your desired list.
| Figure 36: Shows empty 'Favourites' list after the channel has been unselected |
In order to view the Radio List, please click Radio List.
| Figure 37: Selecting 'Radio List' |
All the Radio stations will be displayed
| Figure 38: Radio stations displayed |
In order to view the Television List, please click Television List.
| Figure 39: Selecting 'Television List' |
All the Televisions services are displayed.
| Figure 40: Television services displayed |
In order to get more information about the tool, you can click Help and then About as shown in Figure 41.
| Figure 41: Help menu |
A pop-up window will appear as shown in Figure 42 which will also include the current version number.
| Figure 42: About dialog box |
Sie müssen ein registrierter Benutzer sein, um hier einen Kommentar hinzuzufügen. Wenn Sie sich bereits registriert haben, melden Sie sich bitte an. Wenn Sie sich noch nicht registriert haben, führen Sie bitte eine Registrierung durch und melden Sie sich an.
